High priority create a wall with the same height but with different starting elevation
This topic has been viewed 4195 times and has 2 replies
Pincio
Post by Pincio »
Hello
I would like to know how to create a wall with the same height but with different starting elevation from that of the arrival, both NOT at the floor level.
Thanks for the attention
Country: Paris, France
Re: create a wall with the same height but with different starting elevation
Post by Puybaret »
Not sure to understand your problem. Can't you set the heights you want on walls with the Height at start and Height at end values available in the Wall modification pane?
Miker777
Country: UK
Post by Miker777 »
Hi Pincio
As far as i know, walls always start at 0 (floor hieght), could you use a box (which can be elevated) instead of a wall?
