Print at Oct 17, 2026, 2:24:48 AM
Posted by bdfd at Jan 10, 2017, 4:22:36 PM
Re: arch on half round wall
If I understand correctly, you want to do that ?
If yes, you can use the default object 'arch'.
if no, you must create two walls* which will export in obj format.
You import again the new object and when you see the green arrows, click on up right frame (front view) and then with the mouse and key shift click on the down green Arrow to have 90° and click enter...
You'll have your half arch, see the joined file below.
(*) First wall : standard
Second wall : same than first but 'arc extent' = 90° and joins the twice.
Attachment Half arch.obj (12572 bytes) (Download count: 10380)
