Print at Oct 6, 2026, 5:16:36 AM
Posted by AeowynFraser at Jan 13, 2017, 3:37:28 AM
Re: Tudor Castle version 2
Thank you Miker777. smile
I've finished making changes to the top floor (easily done; only 3 rooms).
No major structural changes; only walls changed were to one closet (so that it matched in size to the other one) and around the bathtub (turned the bathtub around). Doors, door frames, windows, lighting, flooring and ceilings changed just like the other floors.
The Sewing Room/Loft area, two different shots; first from the door to the Master Suite, second from between the chair and computer. There are only a few things that remain from the previous version (the chair, the large cabinet in the one corner and the wardrobe next to it, computer and mouse, sewing machine), a new corner desk unit added to two corners with a hutch added onto each, added the rolling cabinet between the two desks, changed the square table out for the crafting table, and changed the color of the glass on the pendant lamps, and added a mouse pad (actually used the Persian rug and reduced its size to fit on top of the desk then put the mouse on top of it biggrin). The two desks with the hutch and stuff above them are actually mirroring each other.
The Master Bedroom, five views; first from the door to the Sewing Room/Loft area, the rest from the different corners of the room. Changed the framed pictures near the entrance area, changed the bed (kept the same lamps), took out the one small table near the entrance and changed it for a dresser, changed the corner shelvings near the closets from being four floating rounded shelves to a single unit with two shelves. Changed the petals on the lilies to Stargazer lily petals, changed the closet doors and added the closet pole and shelf in each one, took out the bookshelf and moved the TV stand (actually a different one from what I'd originally had) to the other side of the bathroom door, added the full-length wall mirror, changed the dresser in the one corner to a different one. Added a few more pieces of artwork, the Hat and Coat rack in the one corner, and the ceiling fan (including the light source). I think the lighting in this room is just a little too low for my taste, but not too bad (more "mood lighting").
The Master Bathroom, two views; first from the door, second from next to the toilet. Changed the tile, the textures on the shower curtain, bath mat and towel rack (added a second towel rack just behind where the door would open). Changed the wood and marble used on the vanity. Changed the cabinetry next to the vanity and the toilet. Added some towels to the cabinetry next to the vanity. Changed the lighting. I think this room only looks dark because of the dark wood I used.
