Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Some trees & stuff – sharing some of my larger exterior models. » » » » Post: Re: Some trees & stuff – sharing some of my larger exterior models. |
Print at Sep 23, 2026, 4:31:53 PM |
| Posted by Ceciliabr at Jan 14, 2017, 1:19:18 PM |
Re: Some trees & stuff – sharing some of my larger exterior models. @VeroniQ Yes, these are models and textures I have created using combinations of different designer software and my own photographs. The trees and the plants are created with Eon Vue and re-textured in Photoshop, rocks and grass are created with Poser Pro. The terrain is generated from a handcrafted heightfield map. The ground texture is created with various brushes in Photoshop, and is meant as an alternative to the tiled lawns. I have reduced the size to 1,4Mb. The resolution is 4096 x 4096, and it gives the best result if sized between 100 x 100 and 200 x 200 meters. You can of course use everything as you please. Cec |
Current timezone is GMT Sep 23, 2026, 4:31:53 PM |
