Print at Sep 27, 2026, 7:37:03 AM
Posted by rhawke at Jan 27, 2017, 7:19:05 AM
Recalculate Room Points
After I move a wall by a few inches or move a door left or right along a wall, I have to update the room. Right now the easiest way is to delete the room and add it again with double click (because fixing the room to match a moved door manually takes a long time).
But then I have to select the textures again, change labels, etc.
It would be nice to have a button inside the "Modify Room" dialog box that lets you recalculate the room points (basically same calculation as when I double click in the center of the room). You could simulate this by assuming I double clicked into the center of the selected room.
Or is there already a good approach to this problem that I am missing?
