Print at Sep 25, 2026, 3:46:12 PM
Posted by Puybaret at Feb 3, 2017, 6:08:47 PM
Re: Rendering on Windows Server 2008 Possible?
Note that Java 3D 1.6 allows also to run ConsolePhotoGenerator on a Linux server with no X11 Display, if you set the j3d.rend system property to noop .
If you use Sweet Home 3D 5.4, please follow the following instructions:
- Install JDK
- Copy / paste ConsolePhotoGenerator class to a file named ConsolePhotoGenerator.java
- Download SweetHome3D-5.4jar, sunflow-0.07.3i.jar, j3dcore.jar, j3dutils.jar, vecmath.jar and batik-svgpathparser-1.7.jar
- Compile ConsolePhotoGenerator.java with the following command:
javac -cp SweetHome3D-5.4.jar:sunflow-0.07.3i.jar -d . ConsolePhotoGenerator.java
- To generate the file photo.png of a home stored in the file home.sh3d , run the command:
java -Dj3d.rend=noop -cp .:SweetHome3D-5.4.jar:sunflow-0.07.3i.jar:j3dcore.jar:vecmath.jar:j3dutils.jar:batik-svgpathparser-1.7.jar com.eteks.sweethome3d.utilities.ConsolePhotoGenerator home.sh3d photo.png
[Updated links on 2020/03/02 after source code moved from CVS to SVN]
