Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Furniture levels » » » » Post: Re: Furniture levels |
Print at Oct 3, 2026, 10:43:17 PM |
| Posted by Puybaret at Feb 8, 2017, 3:31:39 PM |
Re: Furniture levels Unfortunately, there's no direct way to restore the elevations set before you grouped objects, but you could use the Furniture > Elevate menu item proposed in Advanced editing plug-in to help you change back elevation faster. Note that you should have proceeded differently in the first place to hide objects: you could have selected all the objects you wanted to hide then choose Furniture > Modify menu item to change their visibility at once. You could also create levels at the same elevation as existing ones where you would cut / paste furniture you want to hide, then make the levels with furniture not viewable while you print. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 10:43:17 PM |
