Print at Sep 25, 2026, 6:55:25 AM
Posted by okh at Feb 17, 2017, 9:59:03 AM
Re: Stairs/treppe DHH needed/benötigt
Thank you very much!!
Do you also have those kind of windows?
The answer to your window question is yes ... and no. Yes because I do have several non rectangular windows. No, because they are unlikely to be of much use to you. Angles in my windows are adjusted exactly to what I needed and they will not scale the way you want them. E.g. if you want them wider, the top angle will be wrong. Making such windows that are of general interest is probably not doable. You could, of course search for such models, but I doubt you will find exactly what you need.
However, I made a couple of very simple ones quickly with your approximate angles (very approximate) and without any trimmings - see below.
You are likely to get a better result simply combining several windows from the standard collection. In the examples the Fixed triangle window is combined with Fixed window. The combination will give you much more freedom in scaling to correct proportions. If need be, of course, you can export a group of windows and reimport them as one window. That will make them easier to move around. Good luck. ok
Examples in SF 3d models #405 Strange windows
slashwin.sh3d
.obj files:
slashwin1.zip
slashwin2.zip
