Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Need help for a reasonable fee » » » » Post: Re: Need help for a reasonable fee |
Print at Aug 31, 2026, 3:52:03 AM |
| Posted by Miker777 at Feb 25, 2017, 8:34:05 AM |
Re: Need help for a reasonable fee Hi Vlad If you check out THIS link i think you will find that most, if not all, of the roof sections you need are there, ty okh for sharing them, i have used them myself and they are excellent. Where the eaves sit over the wall this part of the roof will be on a lower level, so add them then raise them into postion, this is best achieved with the magnetism turned off. The worktop can be quite simply created by drawing a room around your cabinets, uncheck the "display ceiling" and "display area" then export this room as an object - import it and name it as worktop, you can then position it (magnestism off) and set its thickness to match that of the cabinets, i find it best to make the cabinet worktops invisible. Hope this helps Mike |
Current timezone is GMT Aug 31, 2026, 3:52:03 AM |
