Print at Sep 30, 2026, 7:52:45 AM
Posted by Puybaret at Mar 3, 2017, 11:15:51 AM
Re: Problem with wall thikness and room surfaces.
Maybe this tip is part of the 5% you don't master yet: you could draw rooms first, then with the wall creation tool, double-click in each room to create walls around it. If you have to draw more than a room, you'll probably have to refine the walls that might be superimposed, but this shouldn't be to complicate. Finally once all walls are up and doors are placed, if you want correct doorsteps, you'll just have to delete rooms and create them again with double-clicks.
