Print at Sep 29, 2026, 5:56:26 PM
Posted by okh at Mar 3, 2017, 2:05:59 PM
Re: Problem with wall thikness and room surfaces.
PITA to draw a thick wall aligned correctly to room borders
It would be, but you do not have to. Just to clarify, if there is a misunderstanding here:
- draw the room with correct measurements,
- make sure the new wall thickness is set correctly in preferences,
- double-click with the Wall tool inside the walls,
- then the walls are created automatically.
If there are different thickness walls, you adjust thickness for those walls, change the start/end values and/or SHIFT-move them. It really does not take that many seconds once you are used to the various commands.
Several of the YouTube SH3D instruction videos do, surprisingly, not cover the automatic room/wall creation.
