Print at Oct 5, 2026, 3:00:04 AM
Posted by mikedeplume at Apr 14, 2017, 6:21:24 PM
Cannot create plan outline
Nor can I create walls or polylines.
I've just installed SH3D 5.4 on Debian and I'm using the java instance that comes with the download.
When start a plan I click on the add plan icon. I then click on the drawing area and drag the mouse. At first, a thickish line is drawn following the mouse but, after a short time (order of 1 second) the line simply disappears. It does seem to be a matter of time rather than distance since I can vary mouse speed and get the same result for different lengths of line. There is a related effect if I try to raise the edit box by pressing enter. I click the mouse and press enter and a box appears and immediately fades.
The same thing happens with walls and polylines.
I'm running from the command line and there are no error messages in the terminal window.
Any thoughts?
