Print at Oct 1, 2026, 3:28:17 AM
Posted by Nio at Apr 22, 2017, 8:03:02 PM
Re: not showing modifying panels
after when i make wall then I select that wall and go to plan and select modify wall but the box (panel) of modify wall which is appear by clicking (modify wall < plan ) is not showing modify wall panel
I mean I can't able to use modify walls also modify furniture , modify room cos the panel (box) is not showing (appearing) but only modify level is working I mean showing its panel
and I didn't do base lock and I do everything systematic ..
if you still didn't understand ..ask it I will again try to explain you ..
