Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Wall's axis change » » » » Post: Re: Wall's axis change |
Print at Oct 13, 2026, 3:14:40 AM |
| Posted by Puybaret at Apr 25, 2017, 7:59:00 AM |
Re: Wall's axis change Sorry, there's no way to change the central axis used to measure walls length. If you don't want to calculate the difference, a workaround could be to draw first rooms and double click in the room with the wall creation tool to create the walls around it. But this won't be a perfect solution either if the walls must have different thicknesses or if you want to draw more than a room. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 13, 2026, 3:14:40 AM |
