Print at Oct 8, 2026, 8:45:36 AM
Posted by AeowynFraser at Apr 30, 2017, 1:46:18 AM
Re: Single Story Bungalow
After revisiting the Tudor Castle recently, I felt like revisiting this one as well. As opposed to making changes to the whole house, this time it's only to the outside. smile
Front aerial. A friend of mine looked at the front and thought the two trees in the front looked odd, so I changed that area to a front sitting porch instead, using the same beams for the back porch for this part too, following the roof line. And the blue rectangles on the roof are solar panels; I might think of adding more maybe.
The graphic I used for the solar panels. I did find a solar panel "furniture" on 3D Warehouse that sits on the roof, but I didn't like the graphic that was used.
I also figured I probably should add a bit of fencing to mark off the back area.
Back aerial. In adding the fencing in the front, I also added a second walkway going around the other side of the house, hooking up with the back door.
Floor plan (with the roofing left visible), mainly to show the new front porch and walkway. You might also notice the car parked in the driveway is really dark. I noticed that when I went to render the front aerial view that the car was coming up a very pale ugly green; getting it this dark got it to render in the nicer green.
