Print at Oct 2, 2026, 1:34:47 PM
Posted by bdfd at May 16, 2017, 9:45:36 AM
Re: Created texture display problem
Hi, I made a new texture (wall tiles) by using guide from Internet (by using Power Point). Than, I put it on the one side of wall on the level 1. Later, I made a level 2 (56 cm above level 1) and moved that wall on the level 2. The problem is texture on the wall doesn't look ok, because it started from level 1. Please help me.
I have had same problem when 2 walls are above themselves. sad
I do this :
Write original coordinates X & Y of the first wall.
Move first of the two walls to see the second and update the texture of the second wall.
Change X & Y to replace the first wall.
It will be OK.
