Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: calculating outside surface of all walls » » » » Post: Re: calculating outside surface of all walls |
Print at Sep 27, 2026, 2:28:33 AM |
| Posted by okh at May 19, 2017, 8:41:11 AM |
Re: calculating outside surface of all walls Actually, there is an easy way: Plugin #5 ComputeWallsSurface will calculate for you (albeit with some caveats mentioned on plugin download page and discussions such as thread 7516: Calculating the surface of the wall). If you take into account that it measures the inside of the wall, it should do pretty much what you want if you install the plugin, restart sh3d, select the outer walls and run the plugin from the tools menu. Good luck with your insulation project. ok |
Current timezone is GMT Sep 27, 2026, 2:28:33 AM |
