Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Open double door needed » » » » Post: Re: Open double door needed |
Print at Oct 12, 2026, 8:07:43 AM |
| Posted by Puybaret at May 21, 2017, 2:56:29 PM |
Re: Open double door needed Bubblobill, thanks for trying but the faces of the 3D model you proposed are not well oriented when imported in Sweet Home 3D : I guess you forgot to select the option Mesh > Normals > Flip Normals on the mirrored door you created in Blender. By the way, it's clearly a work derived from the open door available in Sweet Home 3D and the OBJ file should repeat the same license in its header when you redistribute a modified version (OBJ file is a text file, so it's easy to update it). Of course, you can add in this header your name as a contributor. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 12, 2026, 8:07:43 AM |
