Print at Oct 6, 2026, 8:19:33 AM
Posted by hansmex at Jun 5, 2017, 4:46:58 AM
Re: vertical rounded wall
1st method
- insert an invisible, insertable cylinder
- doesn't work because the cylinder makes a square cut in the wall, not a rounded one
2nd method
- draw a wall that has the desired curvature
- export and import it, rotating it 90 degrees
- could work for a straight wall, but will cause problems in corners
3rd method
- use another program
Sorry
