Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Furniture Library Editor - L4J Look and Feel fix needed » » » » Post: Re: Furniture Library Editor - L4J Look and Feel fix needed |
Print at Oct 5, 2026, 10:32:29 PM |
| Posted by Puybaret at Jun 12, 2017, 6:06:20 PM |
Re: Furniture Library Editor - L4J Look and Feel fix needed A Launch4J ini file works only with exe generated with Launch4J, and the Furniture Library Editor is available only as a Jar executable. If you want to apply the tip proposed to fix Sweet Home 3D problems with file dialog under Windows 10, you should run the editor from the command line, with a command similar to: java -Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel -jar path\to\FurnitureLibraryEditor-1.20.jar---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 5, 2026, 10:32:29 PM |
