Print at Sep 30, 2026, 1:48:18 PM
Posted by Puybaret at Jun 26, 2017, 9:20:03 AM
Re: How to edit a room
I guess you moved the walls, expecting the room points would follow but this is not how Sweet Home 3D works. Select the room surface and move the points to the new wall corners, and you'll see that magnetism will help you place them easily on the corners. You may also delete the room surface and create it again with the room creation tool.
