Print at Sep 28, 2026, 7:49:29 PM
Posted by bdfd at Jun 29, 2017, 5:44:37 AM
Re: real time surface
I try to create a plugin that prints the current surface of all rooms dynamically.
I start learning the compute surface plugin, ok
I succeed in adding a roomlistener and it works. Nevertheless, this callback is called only at the beginning of the creation of a new room.
Can I intercept any other updates like : point moved, drawing finished ?
At present, the last room has a surface of zero. This value is updated only with the correct value when a new room is created
I'm very interested in your plugin.
Can you add as a test: adds the surface of the room if the button 'Display area' is checked stp ?
Please let us know.
I hope you distribute your plugin. applause
