Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 5.5 » » » » Post: Re: Sweet Home 3D 5.5 |
Print at Oct 3, 2026, 11:54:02 AM |
| Posted by dorin at Jul 21, 2017, 11:16:28 AM |
Re: Sweet Home 3D 5.5 About the first improvement door and windows to don't be deformed it work as expected and is great. I've made this furniture but I encounter this issue: The casing are well positioned when the thickness of the wall are the same as the doorOrWindowWallThickness#1=12. I suspect I do something wrong but I don't know what. I modify also other doors and windows from contributors library and some work well but other don't. It appear the doorOrWindowWallDistance#1=1 are computed from the middle of the wall not from the side of wall. Is not necessarily a problem wile I use the arrow keys to correct the position but is a little difficult when are angled walls (different then 90dg). ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 3, 2026, 11:54:02 AM |
