Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: OBJ import problem » » » » Post: Re: OBJ import problem |
Print at Sep 23, 2026, 4:21:50 PM |
| Posted by GertHe at Jul 24, 2017, 2:46:55 PM |
Re: OBJ import problem Learning requires patience ... I managed to split the object by importing them to Rhinocero 5, then "select object -> Export Selected..."Strange that PH3D refused to import the .DAE and .KMZ versions I had exported from Rhino ("format not supported"), but accepted .OBJ only. And that with not very much success either - as you can see in the pic (link) compare what I originally thought I will have (to the left) to the mono-color result. Guess Rhino export and PH3D import are not understanding each other. ...next need to try anim8or |
Current timezone is GMT Sep 23, 2026, 4:21:50 PM |
