Print at Oct 2, 2026, 9:06:15 AM
Posted by Puybaret at Jul 24, 2017, 7:51:19 PM
Re: Sweet Home 3D 5.5
Tonight, the version 5.5 Beta 2 brings the other following features:
- Ctrl + M shortcut to display the preferences panel under Windows and Linux (under macOS, the existing cmd + , is unchanged)
- Ctrl + Alt + M (cmd + alt + M under macOS) shortcut to modify the virtual visitor (Ceciliabr, cmd alt D is reserved to show/hide the dock under macOS)
- To prevent selectioning and showing the virtual visitor in the plan each time a move is made in the 3D view, you can now unselect the new Virtual visitor selected at change option in the preferences panel. But don't get lost! wink
- Angles can now be entered with decimals for more precision
- And after many years, I finally added the ability to rotate furniture (but not doors and windows, staircases and groups) around either their roll (Y) or pitch (X) horizontal axes. Rotation can be changed with the furniture modification dialog.
Once a piece of furniture has its roll or pitch angle set with a value different from 0, it's also possible to adjust this angle in the plan with its bottom left indicator that replaces the one used to modify the height. The height indicator was actually removed because the size indicator can resize only proportionally a piece of furniture that is horizontally rotated, or a group that contains such pieces.
The center of a rotated object in the plan doesn't move after a rotation and its altitude is adapted to ensure that its lowest vertex remains at the elevation set on the object. Angle values increase clockwise the same way as for the rotation angle around the vertical axis in past versions.
- I also added the horizontallyRotatable property to prevent some models to rotate around an horizontal axis if needed. I wonder on which 3D models of the free library I should set this property. Any idea?
- Finally, I fixed the location and icon in the plan for 3D models with a non paralleledipep shape (like a cone), when a rotation different from 90° was applied on it at importation time. This correction won't be applied on existing objects in an opened sh3d file to prevent breaking compatibility.
I sincerely hope you'll like the way I programmed the rotation around horizontal axes, and won't think it overcomplicates Sweet Home 3D.
Dorin, sorry, I don't think I'll change viewable / unviewable words in the user interface, because even if it's subtle, a viewable upper level can still be invisible in the 3D view when the 3D view > Display selected level menu item is selected. It's the reason I chose two different words.
About your other post, I don't see any issue about the open doors you tested. The front part of a door with a doorOrWindowWidthDepthDeformable property set to true is magnetized to the side of the wall where you drop it. In your example, the values of doorOrWindowWallThickness and doorOrWindowWallDistance properties are subtracted from the depth to know the depth of the front part where the open door is, i.e. 98 - 12 - 1 = 85 cm.
In case it wasn't clear enough, the doorOrWindowWidthDepthDeformable property set to false just states that the global width and depth of a 3D model can only change proportionally. Sweet Home 3D doesn't analyze subparts of a 3D model to guess which vertices could move or not. Hope you can live with it...
