Print at Sep 26, 2026, 1:51:53 PM
Posted by Puybaret at Jul 30, 2017, 1:30:06 PM
Re: Sweet Home 3D from Amazon Purchase
What indicates you that it didn't work?
The Windows installer provides both 32 bit and 64 bit versions so the problem must come from elsewhere. The interesting thing with working with the 64 bit version is that it allows programs to use more RAM, which might be necessary for big Sweet Home 3D projects. If your project requires too much RAM, you should try it on a 64 bit computer, or hide the objects which use large 3D models, using their Visible check box.
