Print at Oct 19, 2026, 9:17:43 AM
Posted by hansmex at Aug 17, 2017, 1:08:05 PM
Re: Help needed Improving Plan
You forgot to scale the plans correctly. Your house is anywhere between 35 and 50% too big. So, basically you should start all over again.
My suggestion is to draw the ground floor first, then copy all walls to first and second level and adjust (or delete) as needed. That way walls align perfectly.
See attached file.
