Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: DirectX driver issues in windows 10 » » » » Post: Re: DirectX driver issues in windows 10 |
Print at Aug 27, 2026, 4:32:05 PM |
| Posted by Puybaret at Aug 17, 2017, 9:05:07 PM |
Re: DirectX driver issues in windows 10 If you don't want to run Sweet Home 3D with Java Web Start, try to run the program from its Jar executable version using the following command: java -d32 -jar path/to/SweetHome3D-5.4.jarOnce you found the right command, you can save it in a .bat double clickable file. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 27, 2026, 4:32:05 PM |
