Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Editing a group of vertices » » » » Post: Re: Editing a group of vertices |
Print at Sep 24, 2026, 6:20:26 PM |
| Posted by skunk at Sep 11, 2017, 10:17:20 PM |
Re: Editing a group of vertices But right now, you have the limitation of not being able to make the same modification to multiple objects at once---people asking e.g. how to move a wall, and have the room boundary move with it. I don't think that scenario rises to the level of advanced usage. Yes, modifying vertices can break the consistency, but most of the time the adjustments would be straight X- or Y-axis aligned. And the time to use a tool like this would ideally be before walls are cut anyway. The main reason that I want this is so I can lay down walls using rough measurements, and then be able to adjust everything easily later on when I get more precise dimensions. Right now, I have to have all the exact numbers up front, because changing things after the fact is way harder than it should be. |
Current timezone is GMT Sep 24, 2026, 6:20:26 PM |
