Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Existing and Proposed Condistions » » » » Post: Re: Existing and Proposed Condistions |
Print at Oct 19, 2026, 7:34:32 AM |
| Posted by Puybaret at Sep 20, 2017, 6:05:38 AM |
Re: Existing and Proposed Condistions I would suggest to use three levels at the same elevation : - one where you draw everything in common (walls, rooms and furniture that won't change) - one where you draw things you want to remove or move - a last level where you draw new things. Then you can make viewable either two last levels to view the differences. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 19, 2026, 7:34:32 AM |
