Print at Sep 25, 2026, 6:54:44 AM
Posted by Puybaret at Sep 23, 2017, 5:59:17 PM
Re: AMAZON VERSION export to OBJ issue with furniture
Hum, if you look closer to the result of an Export to OBJ format, you will see that the folder where the OBJ file was created contains also a MTL file and the images of the textures. All these files must be kept together if you want to import your home in other 3D software.
If this is what you did, it's probably that 3D software which doesn't work so well. What software did you try?
