Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to create a down light embedded in the ceiling » » » » Post: Re: How to create a down light embedded in the ceiling |
Print at Sep 24, 2026, 1:09:33 PM |
| Posted by okh at Sep 26, 2017, 11:51:57 AM |
Re: How to create a down light embedded in the ceiling The reason I chose a square was that whether I insert a square or a cylinder into a ceiling, it will make a square hole anyway. Forgive me if I am missing the point here as I have not studied the thread in detail. But if the idea is to create a circular cutout for an object in a ceiling, you will need to add a (circular) SVG cutout path to the object with the Furniture Library Editor. I know there are ways of fixing that, but I haven't yet had time to explore the hidden... Just noticed that a full circle is not really described in the mini-manual, but using the following staircase cutout path, should do the trick for a circle: m 0,0.5 a .5,.5 0,0,0 1,0 a .5,.5 0,0,0 -1,0 zThe cutout above follows the edges of the model, and if the model is scaled with different proportions (oval), the cutout should follow the object. A couple of additional notes for users who wish to explore the details of how this works (no need to read on for most users): - As far as I remember, it is not possible to add both light-source properties AND staircase properties to one object, which means that a cutout model needs to be used with a separate light source. - I also seem to remember that the ceiling cutout only works if there is a level above (?). - The path is not one circle, but two half arcs which for several reasons is the easiest way to create a full circle with the path command. - The SVG matrix used for SH3D is always 0,0 to 1,1. - The format for the Elliptical Arc in a path: - a rx,ry x-axis-rotation largearc-flag,sweep-flag,x,y - Where - - rx and ry are the x and y radii - - x-axis-rotation and largearc-flag make no difference in this case - - sweep-flag 0 indicates direction of the arc - - x and y are the end co-ordinates of the arc (relative to the starting point as a lower case a is used), - - z returns the path to the starting point (and may not be necessary in this case) - As lowercase letters (m,a,z) are used, the co-ordinates are relative, but SH3D can do absolute (capital letters) or a mix too. In fact, I think any thinkable valid SVG path will work. At least, I have not yet managed to come up with a path that SH3D did not handle (but only path - not other elements, like circle). - When I write above that one needs to use the Furniture Library Editor to create a path, that is actually not entirely true. In later versions of SH3D, there is the Home.xml file where it is possible (if maybe not advisable) to edit/add the cutout directly in the model where a cutout is indicated like this: <pieceOfFurniture ....... staircaseCutOutShape='m 0,0.5 a .5,.5 0,0,0 1,0 a .5,.5 0,0,0 -1,0 z' ............../>ok PS Congratulations/Gratulerer, Cec! |
Current timezone is GMT Sep 24, 2026, 1:09:33 PM |
