Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to create a down light embedded in the ceiling » » » » Post: Re: How to create a down light embedded in the ceiling |
Print at Sep 24, 2026, 12:50:07 AM |
| Posted by Ceciliabr at Oct 5, 2017, 9:58:33 PM |
Re: How to create a down light embedded in the ceiling @ okh I didn't get around to try it until to day, but it works and looks very good. And then I got an idea... A downlight embedded in the ceiling must consist of minimum two elements: A pipe (to perform the cut-out) plus a light source, since, as far I have understood it, a 3d model can't hold both a cut-out and a built in light source at the same time. But a reflector with a light source in it should be possible to make, and using a reflector formed as a spotlight with a light source inside it, we will be able to easily rotate the light beam in any direction and almost any angle we want, and not have to worry about the shape of the cut-out. I thought it was worth a try. Well, I gave up. My head wasn't working, so I ended up with a spotlight with no embedded light source. But it works: ![]() This is as far as I got: circle_cutout_with_spotlight.sh3d Maybe you want to give it a try? It's time to put the man in the spotlight... ![]() cec |
Current timezone is GMT Sep 24, 2026, 12:50:07 AM |
