Print at Sep 27, 2026, 4:45:21 AM
Posted by okh at Oct 6, 2017, 10:09:17 AM
Re: How to create a down light embedded in the ceiling
quote].. reflector formed as a spotlight
with a light source inside it, we will be able to easily rotate the light beam in any direction...Yes, it is exactly something like this that would be useful. But to take it to a more generic level, a lamp in the basic collection that can be turned and focus the light in any direction. This should be useful in many contexts.
As for the downlight, another thought struck me. If I remember correctly, a model in a library imported with both lightsource and staircase-cutout will strip either the light-source or the staircase from the properties in PluginFurnitureCatalog.properties.
What if the model/properties was not taken through the import process, but if both lightsource and cutout was added to the model <pieceOfFurniture> manually in the home.xml entry? Shot in the dark, and I do not expect it to work, but unless someone jumps in tells me it will not work, I also will not be able to resist the temptation to try.
But later. My head is not working either. Down with a cold.
PS
And as you know Cec: det er ikke noe sykere enn en syk mann... Så nå har jeg nok med å pleie min selvmedlidenhet. Men i det minste kan jeg avhjelpe med en Calvados i kveld.
