Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Same image – like night & day - a miracle? » » » » Post: Re: Same image – like night & day - a miracle? |
Print at Aug 29, 2026, 2:07:44 AM |
| Posted by Ceciliabr at Oct 9, 2017, 11:33:31 PM |
Re: Same image – like night & day - a miracle? @ enkonyito This is a "normal" behavior of the renderer. Ok. That's good to know. I have noticed some other forms of "unexpected behaviour" that you might interested in: ![]() It seems the wall texture is not rendering like it should when I'm using the Create photo with renderer: Here with the default renderer: ![]() And here with the Create photo with renderer: ![]() The texture of the ground beneath the cobblestones don't look right. It has some kind of waffle-appearance compared to the image rendered with the default renderer. I wanted to see if the same happened at daytime: ![]() It seems it did. Here with the default renderer: ![]() And this is with the Create photo with renderer:: ![]() And, as you can see, it's not only the walls and the ground texture that are different, the bicycle stand and the football also renders with a different looking texture. I have the v1.3.2 version of the Create photo with renderer, and my settings for these renderings are the default settings of Q4. Cec. |
Current timezone is GMT Aug 29, 2026, 2:07:44 AM |
