Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Generating 360 degree stereoscopic images » » » » Post: Re: Generating 360 degree stereoscopic images |
Print at Sep 26, 2026, 4:27:38 AM |
| Posted by qythyx at Oct 11, 2017, 8:33:53 AM |
Re: Generating 360 degree stereoscopic images Thanks for the example. I think I wasn't clear. I'm able to create 360 panoramas fine, and view them. The problem is that I want to create stereoscopic 360 panorama. Those are made from two images, one for the left eye and one for the right. Having this gives depth to the image so you can tell what's further away and what's closer. Here's an example I make, but it has the problem that I described in my first post. When you look towards the window it's fine, but if you look at the corner of the bed platform it's off a bit, and it's even worse if you look at the hanging chair. To generate these images correctly the SH3D renderer would need to render spherical images slightly differently than it does now. |
Current timezone is GMT Sep 26, 2026, 4:27:38 AM |
