Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Printing Walls from side » » » » Post: Re: Printing Walls from side |
Print at Sep 27, 2026, 8:17:18 AM |
| Posted by okh at Oct 20, 2017, 9:57:42 AM |
Re: Printing Walls from side ..I really wonder that this is a feature that I seem to be the only one interested in. It should not be to hard to implement I'd guess. Oh, you are not alone in wishing for a simple way to create a lateral view. The question does come up from time to time, also in the feature requests (SF ticket 484 with links to a couple of similar, closed ones).Oh well, I guess I have to tinker then :) Thanks for your extremely helpful software as well :) In addition to what Puybaret suggests, you may want to look at threads 5416 and 5498 to see couple of approaches. One way is to create a side photo as in Akalvin's house in 5416#23778. Moving the virtual visitor far away (say 50000 cm) and setting the field of view to minimum (2°) before you create the photo, will generate a relatively undistorted side view. Easy with a facade, but will also work with inner walls if you remove (delete) obstructing walls and furniture for the shot. The below test was created by exporting the facade as obj, importing, turning it, shrinking height, and adding dimension lines in SH3D before editing the SVG export with Inkscape. I quite like this way, as the exported SVG will have one px equal one cm when adding/editing objects, so it is fairly easy to edit with high accuracy. Again, not perfect, but maybe good enough for documentation (the wall background would be nicer now with the new possiblity of increasing icon size). ok See closed SF feature request ticket 676 for files used in this example: |
Current timezone is GMT Sep 27, 2026, 8:17:18 AM |
