Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can't open sh3d file » » » » Post: Re: SweetHome3D can not be used |
Print at Sep 26, 2026, 11:40:48 PM |
| Posted by Puybaret at Nov 2, 2017, 8:43:20 PM |
Re: SweetHome3D can not be used Thanks for sending your file. Unfortunately, it contains only zeros and can't be recovered. It rarely happens and I never found how this can happen. You may have still a chance to recover a part of your work, by following this tip: check in the subfolders of C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\work (where user is your login) if there are some files starting by open and ending with .sweethome3d. If such files exist, copy the most recent one, change its extension by .sh3d and try to open it with Sweet Home 3D. Did you encounter some program crash or do you remember something weird that could have happened while using Sweet Home 3D or your computer? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 11:40:48 PM |
