Print at Sep 24, 2026, 7:57:07 AM
Posted by Puybaret at Aug 13, 2007, 2:13:00 AM
Re: Can't run application
The easiest way to run Sweet Home 3D is with its online JNLP file available at http://sweethome3d.sourceforge.net/SweetHome3D.jnlp .
If you want to run it from NetBeans you should run the class com.eteks.sweethome3d.SweetHome3D with the system property java.library.path equal to the lib/windows Sweet Home 3D sub directory (thanks to the Java option -Djava.library.path=path/to/lib/windows).
