Print at Sep 24, 2026, 5:05:08 AM
Posted by okh at Dec 12, 2017, 3:10:20 PM
Re: Sliding door glazed
..add an standard embrasure in black color, for import, click on the option 'door and window', to remove the magnetism to put the sliding door glazed, Put the sliding door glazed near the wall, not in.
Or add library properties (see thread 2006 for the whole shebang), something like this guestimate:
doorOrWindow#1=true
doorOrWindowCutOutShape#1=M 0.029,0.04 h0.46 v.962 h-0.46 z
doorOrWindowWallThickness#1=15
doorOrWindowWallDistance#1=-6.2
Or even edit the <doorOrWindow .../> properties in Home.xml replacing:
wallCutOutOnBothSides='true' boundToWall='false'
by something like:
wallThickness='0.903616' wallDistance='-0.373494' cutOutShape='M 0.029,0.04 h0.46 v.962 h-0.46 z' wallCutOutOnBothSides='true'
Backup first, though, easy to make a mess smile The cutout will be the same in both cases, but in Home.xml all values are relative to model size, also wall alignment. As model is 16.6 deep wallThickness = 0.903616 (15/16.6) and wall Distance -0.373494 (-6.2/16.6).
PS. In light of the hols approaching, all concerned with dietary requirements of models, there is information in SF 3D models 261. Combined with a bit of editor magic, it is quite astonishing how small it is possible to make a model.
