Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Search luminous neon objects! » » » » Post: Re: Search luminous neon objects! |
Print at Sep 30, 2026, 1:51:40 AM |
| Posted by bdfd at Dec 22, 2017, 6:00:21 AM |
Re: Search luminous neon objects! This is really very simple. Amazing. More useful example (i hope): Create your own sign using walls, floors and other objects (furniture). (If you want your floor to have thickness create next level with elevation>0) Apply different colors to parts of your sign (for walls - top and both sides). Select all parts* and Export to OBJ. Modify .mtl - illum to "0" (You can remove some parameters - i think you can leave only newmtl, illum and Kd). Import .obj - rotate, change size if needed, etc. Place in your home and render Q4 (or with plugin - set gI to "path")** *If you want to cut hole in floor draw smaller floor shape inside(on it) and don't select it for exporting (see "O" in "GLOW") ** No glowing when sky has texture Download glow.sh3d Bravo Alax ! ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
Current timezone is GMT Sep 30, 2026, 1:51:40 AM |
