Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: In a hole in the ground there lived a hobbit... » » » » Post: Re: In a hole in the ground there lived a hobbit... |
Print at Sep 26, 2026, 8:47:01 PM |
| Posted by Ceciliabr at Dec 22, 2017, 10:34:09 PM |
Re: In a hole in the ground there lived a hobbit... A few words about this project: Using Levels. Using multiple levels can be very helpful, not only for separating floors, but also for making projects easy to organise. In this project I use 8 levels. The ground Using a dedicated Ground level might seem unnecessary since a texturable ground is automatically provided, but here is one good reason for defining your own Ground Level and use a dedicated ground object: In nature, objects are often sticking up from the ground rather than just lying on the surface. Using my own ground, like a flat terrain or a plane created from a box, I can place an object on a level beneath the Ground Level so it appears to be lying “into” the ground, and not only “on top of” the ground. Terrains There are several inexpensive or even free 3D-apps that can generate 3D terrains from height maps, and hand crafted height maps can easily be painted in Photoshop or Gimp. A height map will typically use black as zero level, and then rise the terrain relative to the whiteness of the greyscale with absolute white producing the highest level. I wanted my mountain to have an unnatural form – sharp and edgy, as if it belonged to another world. Here is how I created it. The interiors This is the floor plan: ![]() And here are some shots of the main hall. ![]() ![]() ![]() More detailed renders will follow Cec |
Current timezone is GMT Sep 26, 2026, 8:47:01 PM |
