Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: More questions » » » » Post: Re: More questions |
Print at Oct 13, 2026, 1:41:27 AM |
| Posted by Puybaret at Oct 3, 2007, 1:11:00 AM |
Re: More questions Sweet Home 3d doesn't support multiple floors at this time. The only trick you can do is to add a box to simulate a floor and change the elevation of all the furniture you want to put on the second floor. The elevation is always positive so you can't make a staircase so that it starts from the ground going up. If you find an importable railing you may use it instead of low walls. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 13, 2026, 1:41:27 AM |
