Print at Sep 24, 2026, 1:03:18 PM
Posted by ndorigatti at Jan 8, 2018, 3:08:15 PM
Re: Wall Light with reflect effect?
Hello okh,
according to the answer and various posts, this is the updates I got, I'm quite happy about it, I just need to make it even better... Probably i should reduce some light sources on the sides and the front part, but they are already at the minimum size and power (0,1cm and 1% lightning)...
I think i'll need to export to obj and modify manually the lights...
There is still an ugly result on the front part, where the circle light is correct (it does the same at home, but the grey part around is wrong. In the second file, I tryed to fix it with a small daylight in front of the lamp but is still not perfect... Any idea on that?
Thanks again!
