Print at Sep 24, 2026, 2:15:09 PM
Posted by okh at Jan 8, 2018, 9:22:21 PM
Re: Wall Light with reflect effect?
Hansmex point is probably the best advice. Or as Cec said - a bit of cheating (with external, large lightsources).
I think i'll need to export to obj and modify manually the lights...
Just for the record. In the .obj/.mtl you can only set the glow as explained in the alaX link above. If you want to add lightsources to the lamp model, you need to use a furniture library and edit PluginFurnitureCatalog.properties with (multiple) lightsource(s). Not black magic, but it may take a while the first time. All in all, the easier way - and the way of the pro renderers - is using external lightsources. As Hansmex says - bigger is probably better for your effect. Good luck. Keep us posted. ok
