Print at Sep 25, 2026, 6:53:16 PM
Posted by Puybaret at Oct 12, 2007, 10:00:00 PM
Re: AOI - colored objects?
One more thing about windows : In the current version of Sweet Home 3D (and that probably won't change before a long time), the intersection between a window and a wall is computed from the bounding box of the window. This means that the hole in a wall where the window is placed is always rectangular.
For the windows set you want to create, you'll have to add in your 3D model some wall parts at the left and the right of the rounded part of the upper window, otherwise these parts will appear as holes in Sweet Home 3D. The drawback of this way of doing is that these two parts won't be automatically of the same color as the wall the window is placed into (personally, I would set a white color on these two parts, because most people have white painted walls).
I hope my explanations are clear enough... ;-)
