Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Making a door » » » » Post: Re: Making a door |
Print at Sep 24, 2026, 5:42:58 PM |
| Posted by Puybaret at Nov 4, 2007, 3:39:00 PM |
Re: Making a door Nice door ;-) First note that the intersection between a wall and a door or a window is based on the bounding box of the door or the window. Maybe you should add some kind of a thin frame around your door, and set the depth of that surrounding frame in such a way it matches the wall thickness (I used 25 cm or 9.842 inches for that kind of wall). If you want to, send me your file so I can test it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 5:42:58 PM |
