Print at Sep 24, 2026, 10:54:12 AM
Posted by Puybaret at Dec 14, 2007, 8:57:00 AM
Re: Question about DefaultFurnitureCatalog.ja
Hi enzymer,
I just tested the issue you mentioned, but on my side, DefaultFurnitureCatalog is called only once at application launch, and if I comment the readFurniture call for ContributedFurnitureCatalog.properties, Sweet Home 3D shows only the furniture of DefaultFurnitureCatalog.properties as expected !?!
Are you sure you didn't make any other change in the code ?
On which system and JRE did you do these tests ?
