Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Question about DefaultFurnitureCatalog.java » » » » Post: Re: Question about DefaultFurnitureCatalog.ja |
Print at Sep 24, 2026, 2:14:59 PM |
| Posted by enzymer at Dec 15, 2007, 4:37:00 AM |
Re: Question about DefaultFurnitureCatalog.ja Hi epuybaret, Thank you for your test. My OS is Windows XP and IDE is Eclipse 3.2.2 - An hour ago, I tested again but still met the same 2 problems: The DefaultFurnitureCatalog is called exactly 316 times, so the initialization is slowed down (but eventually it will work). I went to another "clean" computer with Windows XP as OS and installed JAVA 1.6 & Eclipse 3.2.2(so, it's not because of my developing environment), re-extract the v1.2 source code from zip file and run(so i just change the constructor of DefaultFurnitureCatalog, nothing else), unfortunately, the same 2 problems happened to me, and exactly 316 times too! For software running under windows, I copy the 4 j3d dll lib files to C:\WINDOWS\System32\ . Is this the key to this problem , i don't know much about dll. Thanks again! |
Current timezone is GMT Sep 24, 2026, 2:14:59 PM |
