Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: zoom for HTML5 tool file is weak compared to program zoom » » » » Post: Re: zoom for HTML5 tool file is weak compared to program zoom |
Print at Sep 26, 2026, 2:37:39 AM |
| Posted by PacWood at Mar 14, 2018, 7:42:19 AM |
Re: zoom for HTML5 tool file is weak compared to program zoom Hello, Thank you for your help. Yes, the HPC.getUserPreferences should have been HPC.getUserPreferences() with the parenthesis. Thank you. I have noticed that there is still an "undefined" error when I use the obj returned by HPC.getUserPreferences() with the code below. I set a break point to follow the error, and then the "undefined" error when away and I can see in the UP variable that the "AerialViewCenteredOnSelectionEnabled" was set to 'true'. It then occurred to me there is a timing issue. The UserPreferences obj returned by HPC.getUserPreferences() is undefined until after the "Home" is loaded. How can I tell when the "Home" is loaded? Is there some global flag somewhere that I can periodically check to make sure the "Home" is loaded into memory? I am thinking that after the "Home" is loaded, then I can safely call "HPC.getUserPreferences();" Below is the code being used now: Thank you much. |
Current timezone is GMT Sep 26, 2026, 2:37:39 AM |
